Page 2 of 3
Re: taffy copy pipe probs
Posted: Sat Mar 02, 2013 8:04 pm
by rosscla
Can't you loosen the stand brackets and move it 5mm to the right?
Posted: Sat Mar 02, 2013 8:12 pm
by carlos fandango
thebassmasta wrote:its not a stainless stand
oh, right, sorry
still might need to bend it out though.
Posted: Sat Mar 02, 2013 8:13 pm
by 10 inch Terror
My bad
where did you get it from? If its from Asia it could be a dodgy one. Don't get me wrong not all Asian stuff is rubbish but a lot of it is. I would try a genuine SIL one from Scooter restorations or a genuine Innocenti one.
Posted: Sat Mar 02, 2013 8:41 pm
by thebassmasta
the stand came with the scoot, sat perfect with a pm pipe on it, the stand will not move over even if i loosen the stand fixings either, it needs to move over around 50mm not 5mm.
Posted: Sat Mar 02, 2013 9:30 pm
by Eibar
does this pipe have a separate u bend section, if so could main expansion not slide further onto u bend by trimming down the lugs on that huge alloy front exhaust bracket by a few mm or removing what look like rubber inserts if thats what they are
Posted: Sat Mar 02, 2013 11:05 pm
by thebassmasta
going to have another look tomorrow, had to walk away from her tonight, really pissed off at the moment
Posted: Sun Mar 03, 2013 11:22 am
by T5-190
I remember modding a stand for a mate a few years ago. He was using a genuine Taffy pipe. I added about 12mm to the width of the stand.
Posted: Sun Mar 03, 2013 11:53 am
by mickdale
Eibar wrote:does this pipe have a separate u bend section, if so could main expansion not slide further onto u bend by trimming down the lugs on that huge alloy front exhaust bracket by a few mm or removing what look like rubber inserts if thats what they are
took 5mm from both sides of the slip joint and "tweeked" the fitment - it helped kink out the tailpipe away from the rear side panel - used a scooter loopy john fixing and worked well - the secret is to not have the exhaust stressed when loosly fitted as they tend to crack/fail otherwise
dont you just love lambrettas
Posted: Sun Mar 03, 2013 2:53 pm
by thebassmasta
all sorted now, just pissed about with the stand and a blow torch
Posted: Sun Mar 03, 2013 4:06 pm
by tavspeed
i would now check the ground clearance of the stand on right handers,you dont want it digging in and launching you off,just a thought as it looks well outside your runner board.
