clutch breather
ducksta
noticed the extra lugs on the clutch housing interesting, do you just drill and tap the inside or do you need extra weld internaly
OzOAP
Main scooter: Vespa PTS1E
Built up with weld externally, milled flat then tapped 6mm.
Two lugs welded to clutch cover.
Have cracked a few casings across the layshaft hole, on motors a lot less powerful.
This one has done about 10k now...still holding together.
