Re: special runs better with choke on.
Posted: Sun Feb 10, 2013 3:21 am
Cheers russ. i will look out for some champion ones
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
carlos fandango wrote:The heat range on champion goes the opposite way to ngkBoothy_the_makem wrote:Yes ngk
To add to the plot a mate called round today . said 5 of them went on a run last year. all filled up at that station and ALL broke down
What is the equivalent champion plugs for the ngk 7's and 8's ?
NGK lower number is a hotter plug ..Champion lower number is a colder plug
A b8es is equivalent to a N3
if you take away the plug number away from 11 it will give you the other make equivalent
So an NGK B7 is eq. to champion N4( this method dosent work for the entire range but does for the common lammy plugs )
But i use a N3 in all my engines with no problems Std 200 to RB240![]()
Russ
