Page 2 of 3
Re: is there any reason why......
Posted: Thu Feb 07, 2013 10:35 pm
by rosscla
I see a vega in the second shot?
Posted: Thu Feb 07, 2013 10:40 pm
by mick1
possibly going into an LD frame ??
Posted: Thu Feb 07, 2013 11:08 pm
by tea5ive
With a bit of luck its going in my Vega. It's a parmakit 130 reedvalve kit for a smallframe vespa. The case is a j125 starstream
Posted: Thu Feb 07, 2013 11:26 pm
by carlos fandango
I like that
What crank are you going to use ?
Posted: Thu Feb 07, 2013 11:43 pm
by tea5ive
carlos fandango wrote:I like that
Sunny with a slight mod and a 105mm rod. Stroke 48mm might have to trim a bit off the cylinder or head or both ideally it would need a 51 stroke '
Posted: Fri Feb 08, 2013 12:14 am
by GP240
I like that, hope to see it working.
Posted: Fri Feb 08, 2013 12:45 am
by Toddy
Thought you was quiet in the garage tonight mate to many things running through your head
And you didn't break any of my tools
Posted: Fri Feb 08, 2013 10:29 am
by tea5ive
Toddy wrote:Thought you was quiet in the garage tonight mate to many things running through your head
not quiet mate, you had a big crowd last nite
, banned from mag flange bearing swaps now that i have bust your new gadge, jossie will do em from now on
Posted: Sat Feb 09, 2013 1:31 pm
by RICSPEED
tea5ive wrote:please remove from your heads the convetional position of exhaust and carb position before answering
i get you now
Posted: Mon Feb 11, 2013 7:05 pm
by RICSPEED
so ..why not stick with your first plan and have the carb forwards .. ill bet that manifild as it is would curve its way round the frame nicely .. pipe out the back ..and i know a pipe fab guy near me .. bang on .. so
do you intend to fit an adaptor plate or weld up ?? how does the j motor compare stroke wise to a smallie motor ??
