electric problems p range
smoore-gt225
Main scooter: lambretta GT200
sorted put 10 watt indicator bulbs in and it just dips slightly at tickover but doesnt dip at all with revs :D :D
soulboy
ill try that mate
paul213
check the horn button , take the switch out of the bars and clean the switch for some reason all power from engine for the lights is fed up unregulated to the horn switch down to the horn and then back to the regulator then back up to headset regulated for the lights etc if the horn switch gets dirty it allows a little current down to the horn which isn't enough to make it sound but reduces the amount of power available for every thing else.
soulboy
my front indicator bulbs are 21 watt :shock: :shock: :shocking:
