Page 2 of 2
Re: Strange noise coming from the kickstart shaft
Posted: Wed Apr 29, 2009 5:48 pm
by andylaw7
good idea panosk ;)
Posted: Wed Apr 29, 2009 6:11 pm
by PanosK
Forgot to mention .
That part was trimmed aswell.
THANKS ROB :)
ROB wrote:i hade to file down the red section:
check as well the shim that is in the picture. there should be no play inbetween casing and shim.
Posted: Wed Apr 29, 2009 6:15 pm
by dirtyhandslopez
Machineists bluing ink works well for that also. It's a little thinner. I usually just put the sidecase on with three or four nuts and turn it over with the kickstart when the motor is on the bench and check for rubbing. Saves a lot of time.
