Strange noise coming from the kickstart shaft
andylaw7
good idea panosk ;)
PanosK
Forgot to mention .
That part was trimmed aswell.
THANKS ROB :)
ROB wrote:i hade to file down the red section:
check as well the shim that is in the picture. there should be no play inbetween casing and shim.
http://vespaclubvolos.com
http://www.lambretta-club.gr
dirtyhandslopez
Machineists bluing ink works well for that also. It's a little thinner. I usually just put the sidecase on with three or four nuts and turn it over with the kickstart when the motor is on the bench and check for rubbing. Saves a lot of time.
That's not going anywhere...
