Re: piston to bore clearance
Posted: Mon Jan 21, 2013 10:40 pm
The only really accurate way to determine the clearance is to measure the piston and the bore and then subtract one from the other. The clearance is the distance between piston and bore when the piston is exactly in the centre of the bore. In other words the gap all of the way around the piston.camel wrote:No a 12 thou feeler gives you 12thou clearanceMuppet wrote:so im lookin at 12 thou feeler for 6 thou cleerence?
If you stick a feeler gauge up one side then the piston is no longer central since it is pressed against the opposite wall of the cylinder to the feeler gauge. Hence you have to halve the value of the gauge. It is also worth remembering that this measurement should be taken at the skirt of the piston since they are manufactured with a very slight taper to allow for expansion at the top where it's hottest.
If any of the above gives the impression that I know what I'm talking about, don't be fooled. I've just read a lot about piston clearances on the internet over the last couple of days.
