Re: 12volt points set-up
Posted: Fri Jan 18, 2013 2:50 pm
I suppose if you could convert a stator to a 12v set up you could then use the 12v regulator and CDI unit from a standard electronic kit. Or isn't it as simple as that?
Well you'd need to change the flywheel, ignition feed coil, and add a pick up unit as well. But once you've got decent lights, why would you want to make it unreliable again?Doom Patrol wrote:I suppose if you could convert a stator to a 12v set up you could then use the 12v regulator and CDI unit from a standard electronic kit. Or isn't it as simple as that?
