Re: Stator Plate problem
Posted: Tue Jan 15, 2013 4:01 pm
Ya need a multi set t ohms an your read resistens cold; when it's hot ya do sames befor an ya wear thick gloves so ya don't get burned,
muppet
muppet
ha ha thanks... wish I understood what you wrote tho lolYa need a multi set t ohms an your read resistens cold; when it's hot ya do sames befor an ya wear thick gloves so ya don't get burned,
muppet
dopeshots wrote:the stator plate wasn't working....
That's because the hot and cold readings shouldn't be significantly different. The reason for checking when hot is to see if the insulation is breakining down as the engine warms up. I don't personnally think heat would be an issue, it would more likely be vibration. Try connecting your meter and gently tapping the coil with a non conductive implement.dopeshots wrote:No not when hot as when i phoned CamLam they couldn't give me any reading for when it was hot only when cold. We tested the resistence when cold and it was outside the perameters they suggested.
I still have the old units does anyone have details on how to test cold and hot so I can double check????
But not while its running...coaster wrote:Try connecting your meter and gently tapping the coil with a non conductive implement.
When I tested the wires I put the earth on the blue wire as thats the earth according to the wiring diagram and the the positive to the rest of the wires..coaster wrote:Were those reasdings all to earth? they seem way too low. Red (pickup) to earth needs to be between 95 to 100 ohms
Green (LT coil) needs to be 450 to 500ish ohms
With Is earth so should be very close to o ohms (yours is close enough)
