Page 2 of 2
Re: Measureing deck height.
Posted: Mon Apr 27, 2009 11:12 pm
by YAMLAM
at BDC ,it looks flush with the exhaust and about 1mm below transfers.
Posted: Mon Apr 27, 2009 11:27 pm
by sean brady scooters
ok matey..
moving on...........
you also said your head was recessed ..........?
do you just mean re profiled to suit piston or recessed as in it fits down into barrel by an amount.........?
some pics would be helpfull if poss.............
but anyway............when head is fitted.............what squish clearance do you have........?
and what head gasket thickness are you using if any...........?
Posted: Tue Apr 28, 2009 7:34 am
by YAMLAM
the head was reprofiled by harry barlow to suit the piston (yam it175) it doesn`t sit in the barrell, the recess is in the actual head,will try to do a picture later.brand new casing.no base gasket. was told to bolt barrel on without,then measure deck height(hence original question) .many thanks for your help sean.
Posted: Tue Apr 28, 2009 7:35 am
by YAMLAM
will check squish tonight and hopefully get pictures up.
Posted: Tue Apr 28, 2009 8:40 am
by CT.
BTW, there's a good explantion of how to measure deck height on Mac Dizzy + lots of other interesting stuff too..
http://www.macdizzy.com/cylinder_map4.htm
Posted: Tue Apr 28, 2009 9:10 pm
by YAMLAM
got some pictures...............how do i display them? :oops:
Posted: Tue Apr 28, 2009 9:58 pm
by drunkmunkey6969
YAMLAM wrote:got some pictures...............how do i display them? :oops:
See here: http://scooterotica.org/forum/viewtopic.php?f=10&t=22
