Page 2 of 3
Re: air filter or not
Posted: Thu Jan 10, 2013 5:40 am
by RManson
Couldn't imagine not running an air filter on any type of street application. All kinds of stuff can get sucked into the engine and engines don't usually like objects being sucked into them.
I'd take the drop in performance that adding an air filter might present over running the risk of sucking in a small bird through the inlet and grenading the engine. Cheap insurance and all that.
-Ryan
Posted: Thu Jan 10, 2013 2:28 pm
by Adam_Winstone
CANbus wrote:Adam_Winstone wrote:http://lambretta.co.uk/catalog/product_ ... ts_id=3178
I note that they have a large range of other filters too, incl. what appears to be a decent size RamAir that is made to their size requirement. These may be worth considering as the hose that somes with the Breathe Sweet filter may not fit your carb. Best thing would be to give them a call and talk through your specific requirements (carb, otor, etc.)
Is that filter element tapered?
I have found most filter elements are parallel and contact the inner side panel when mounted.
Thus loosing this effective area for air intake. I always glue a rubber grommet on my hose to ensure the element is lifted off the inner panel when fitted.
I run short CDC manifolds, the angle of which means that the hose and filter lean towards the frame and don't sit against the panel.
Posted: Thu Jan 10, 2013 3:18 pm
by tonydevon
after chatting with the shop, they have recomended the breathe sweet, so thats what Im going to order tomorrow.
Posted: Thu Jan 10, 2013 3:32 pm
by soosh
-Ryan
You heard of anyone getting a small bird sucked into an engine?
Posted: Thu Jan 10, 2013 4:17 pm
by warts
Isn't it part of a quote from one of the '20's or '30's tuners at Brooklands talking about some hooge carb?
"Big enough to suck in birds and small boys..."
Posted: Thu Jan 10, 2013 5:11 pm
by soosh
Maybe,i dont know.
Posted: Thu Jan 10, 2013 6:57 pm
by byron
yeah, but you don't get that
bwooaaarrrpp induction roar with a filter
tunnels and built up areas won't be so good
of course, using a filter is the sensible option for ring life etc...
Posted: Thu Jan 10, 2013 9:03 pm
by sean brady scooters
so, open carbs for max performance then and filtered carbs for poss extended reliability at the lack of performance ,take your choice folks
Posted: Thu Jan 10, 2013 10:20 pm
by soosh
sean brady scooters wrote:so, open carbs for max performance then and filtered carbs for poss extended reliability at the lack of performance ,take your choice folks
Roar and performance for me
Posted: Thu Jan 10, 2013 11:23 pm
by Andy Pickering
Theirs a sort of parallel with sex really when you think about it
Condom or bare back?
