Page 2 of 2
Re: Honda 205 barrell?
Posted: Wed Apr 29, 2009 5:15 pm
by jonny snatchsniffer
remove 2mm from the top of the barrel gasket face
Posted: Wed Apr 29, 2009 8:54 pm
by maxi
What's the best stuff to make gaskets out off?
Posted: Wed Apr 29, 2009 10:16 pm
by Knowledge
Do you mean gasket, or spacer?
If you mean spacer, use ali sheet. Buy it off ebay if you haven't got a stockist nearby. If you do have a stockist, ask to look in the scrap-bin. There'll probably be something in there for you and charge you a quid or two. Nice.
If you meant gasket, then you can buy gasket paper.
Posted: Wed May 16, 2012 7:02 pm
by ROB
can i use the honda piston just with the rings or do i need this thin wire that sits under the ring?
lost it
Posted: Thu May 17, 2012 9:40 pm
by wack 63
It will be fine without the wire ring and AF's do alloy pack plates in various thicknesses.I rebuild a mates some years ago that was originally done by Harry Barlow and the porting was quite conservative,170 ex,145 inlet and standard transfers with an Amal mk2 30mm and a HB pipe with SX gears and it goes like stink.
Posted: Fri May 18, 2012 11:41 am
by alcoholic maniacs sc
used an RS205 honda for about 15 years tv200 barrell with a 30mm dell'orto and a rs clubman and it was a rapid machine for a basicish iron barrell, seized it a few times with excessively high cruising speeds but all in all a great iron barrell alternative when runing well. probably did 40,000 miles before it went into a mates engine, a good 60 mph cruiser and easily gets over the 70 mark. i'd have another anytime.
Posted: Fri May 18, 2012 11:48 am
by stokky
followed thread on this, and although has part numbers for rings, did not see name of dealer or where they came from.
I have 2 Taffspeed tuned H205' engines, and I love them to bits.
(one unused and been sat in garage for last 4 - 5 years !!)
One has done over 10000 miles, and now needs something doing.
I have a first oversize MTX200 Honda Piston
So in reality looking for Honda MTX200 standard rings or first oversize, anyone help ?
Martin
