Page 2 of 3
Re: winter rebuild
Posted: Tue Jan 01, 2013 5:00 pm
by RICSPEED
thanks ..found his site now ..looks like 50mm to order but would be spot on for mounting water pump i think
Re: winter rebuild
Posted: Thu Jan 03, 2013 6:38 pm
by martinr
wheels done .arse of a job that is
Re: winter rebuild
Posted: Tue Jan 08, 2013 9:28 pm
by martinr
bit more done
Re: winter rebuild
Posted: Thu Jan 17, 2013 10:35 pm
by martinr
front and rear brakes done
Re: winter rebuild
Posted: Thu Jan 17, 2013 10:48 pm
by Stokie
Is there a reason why the rear disc caliper has to be in that position? Could it not be mounted on top or at say 3 o'clock and give better ground clearance and run a shorter hose?
Re: winter rebuild
Posted: Thu Jan 17, 2013 11:46 pm
by Junglemod
Nice work there mate !!!!!
Hope you've got a heater in that shed ,nice work space for a rebuild.
Re: winter rebuild
Posted: Thu Jan 17, 2013 11:51 pm
by tonydevon
cool build
where did you get the front shocks?
Re: winter rebuild
Posted: Fri Jan 18, 2013 9:58 pm
by martinr
cheers chaps theres quite a lot of ground clearance it looks closer in the pics 8-) .the front shock are from frank sanderson then i got the springs powder coated orange
Re: winter rebuild
Posted: Sat Jan 19, 2013 9:23 am
by Toddy
Looking very nice are the floorboard runners laser cut ?
Re: winter rebuild
Posted: Sat Jan 19, 2013 11:25 am
by Andy Pickering
Toddy wrote:Looking very nice are the floorboard runners laser cut ?
Been thinking along the same lines myself :D, with grip tape underneath and patterns similar to the pinstriping that Col did on the paint, what have you used Martin 2mm brushed ally or S/S.
