Re: Lucas pathfinders
Posted: Mon Nov 26, 2012 11:03 pm
OK, Fair enough - I stand corrected! I've since discovered there were some 12Volt Indian GPs wired with 2 sets of lighting coils in parallel, but most setups these days seem to have 4 coils in series. Using the parallel setup may theoretically mean the engine speed needs to be a bit higher to reach 12Volts, but who knows?
The LDA used stator coils with more laminations, so they were non-standard in the first place, although the wire thickness was similar if not identical to the 6 Volt direct lighting coils. I suspect that with the inefficient selenium plate rectifiers of the 1950s (no silicon rectifiers back then), the system needed all the voltage it could get to allow for the forward volts drop through the rectifier!
