Page 2 of 2
Re: piston info required to use in port timing calculator
Posted: Sat Nov 17, 2012 2:07 pm
by Avantone
tea5ive wrote:when looking from the base of the cylinder up the bore with the piston in and at
tdc the two smaller transfers are obscured by the piston skirt, is it worth trimming back the skirt ?
No, the transfer windows have long closed at TDC so what you do with the skirt doesn't come into play at this point in the cycle.
However, it's worth aligning the piston in the correct plain with the transfer windows just opening (being uncovered as the piston moves from TDC to BDC) to then see if the skirt obstructs the transfer cut outs in the base of the cylinder.
Posted: Sat Nov 17, 2012 2:23 pm
by tea5ive
Muppet wrote::wtf: trim skirt where for what?
near the transfer windows, the smaller of the two on each side of the cylinder and from bottom of piston at the inlet side, and in this aplication around 2.5mm to be trimed to get an inlet duration of around 150 ish degrees
Posted: Sat Nov 17, 2012 2:29 pm
by tea5ive
yes, will be doing this as i have done with other cylinders when maching to casings etc.
Avantone wrote:tea5ive wrote:when looking from the base of the cylinder up the bore with the piston in and at
Posted: Sat Nov 17, 2012 2:36 pm
by tea5ive
what about port widths ?, die grinder waiting
Posted: Sat Nov 17, 2012 3:56 pm
by Avantone
tea5ive wrote:what about port widths ?, die grinder waiting
I'd address the inlet duration first an then see what TA you get against what you need (see posts on timed area).
It's also worth assessing the cross sectional area of the inlet tract from carb to cylinder wall to see if there's a steady transition, or whether it fluctuates and/or restricts.
Posted: Sat Nov 17, 2012 6:56 pm
by tea5ive
thanks for the help tony and eden,
can you tell me how and where to measure the timed area ? . i think the next step is to get the top end on a casing with a crank and see how things line up. cheers simon
Posted: Mon Nov 19, 2012 10:04 pm
by jonny snatchsniffer
cutting the skirt of the piston is the easy way to get more inlet duration but actually enlarging the port will give better results, the exhaust pot widening will depend on your rings
