Re: Bar Grip sizes?
Posted: Wed Nov 07, 2012 6:47 pm
well ..that was partly the idea so i could fit morax end caps .. ill have a dig around for the dimensions .. these replace the plastic rod ends and you will need to drill them to suit your rods .. then spot weld to lever supportcorrado wrote:..... but if you remove the horrible Blue end bung it'll probably be spot on.corrado wrote:With the particular grip in question that plug wouldn't work Rich. Might be perfect with the end part machined off though.
How much for a pair Rich?
