Bar Grip sizes?
corrado wrote:
corrado wrote:With the particular grip in question that plug wouldn't work Rich. Might be perfect with the end part machined off though.
..... but if you remove the horrible Blue end bung it'll probably be spot on.
How much for a pair Rich?
well ..that was partly the idea so i could fit morax end caps .. ill have a dig around for the dimensions .. these replace the plastic rod ends and you will need to drill them to suit your rods .. then spot weld to lever support
sparklymarkly
Got mine sorted.
Took the 'wrong' ones back to Readspeed and got some TZR type and matching bar ends from MB.
Job for the weekend.........
    Users browsing this forum: Semrush [Bot] and 9 guests
