Page 2 of 2
Re: now for the rear brake light ! help
Posted: Mon Oct 29, 2012 1:39 pm
by rbgaz
just fitted the bikevis bullet lights to the front very impressed would def recomend :anbrgin;
Posted: Thu Nov 01, 2012 9:43 pm
by YAMLAM
[quote="rbgaz"]right wired rear light to battery that was easy even for me .
Can i ask how you did this , as i am trying to do the same on my cutdown .
Posted: Fri Nov 02, 2012 7:24 am
by rbgaz
yes yam the year light is fed by one black wire that gets feed of the bulb holder in the front just take it out and wire it up dierect from u battery ive done the rear light as well as speedo/park/and led bullet lights just waiting for some rear bullet lights to turn up and a dc horn i turn them on with a 12volt dc toggle switch on the headset that i got from maplins
Posted: Fri Nov 02, 2012 10:21 am
by YAMLAM
Thanks for that , was hoping to be able to still use the normal key switch, but dont think its possible because of mixing ac/dc feeds together, unless someone knows different ?
Posted: Fri Nov 02, 2012 10:52 am
by firekdp
YAMLAM wrote:Thanks for that , was hoping to be able to still use the normal key switch, but dont think its possible because of mixing ac/dc feeds together, unless someone knows different ?
As mentioned before, an Indian ignition switch will do the job for you.
Posted: Fri Nov 02, 2012 5:18 pm
by YAMLAM
Thanks Firekdp.
Posted: Fri Nov 02, 2012 6:18 pm
by firekdp
YAMLAM wrote:Thanks Firekdp.
No problem, if you need any help, with a diagram or such, give us a shout.
Kev.
Posted: Fri Nov 02, 2012 6:30 pm
by joespeed
for the none sparky type,this is for you gaz,take a two core wire connected to the brake light switch ,one colour in each connection run the wire up the main frame tube into the headset top out to the handle bar switch connecting one wire to each terminal anyway round,simples!
Posted: Thu Nov 08, 2012 5:18 pm
by rbgaz
have now done this and works treat never had a brake light so bright before
