now for the rear brake light ! help
rbgaz
just fitted the bikevis bullet lights to the front very impressed would def recomend :anbrgin;
YAMLAM
[quote="rbgaz"]right wired rear light to battery that was easy even for me .
Can i ask how you did this , as i am trying to do the same on my cutdown .
win or lose have a booze
rbgaz
yes yam the year light is fed by one black wire that gets feed of the bulb holder in the front just take it out and wire it up dierect from u battery ive done the rear light as well as speedo/park/and led bullet lights just waiting for some rear bullet lights to turn up and a dc horn i turn them on with a 12volt dc toggle switch on the headset that i got from maplins
YAMLAM
Thanks for that , was hoping to be able to still use the normal key switch, but dont think its possible because of mixing ac/dc feeds together, unless someone knows different ?
firekdp
YAMLAM wrote:Thanks for that , was hoping to be able to still use the normal key switch, but dont think its possible because of mixing ac/dc feeds together, unless someone knows different ?
As mentioned before, an Indian ignition switch will do the job for you.
YAMLAM
Thanks Firekdp.
firekdp
YAMLAM wrote:Thanks Firekdp.
No problem, if you need any help, with a diagram or such, give us a shout.
Kev.
joespeed
for the none sparky type,this is for you gaz,take a two core wire connected to the brake light switch ,one colour in each connection run the wire up the main frame tube into the headset top out to the handle bar switch connecting one wire to each terminal anyway round,simples!
rbgaz
have now done this and works treat never had a brake light so bright before :shock:
    Users browsing this forum: Google [Bot], Semrush [Bot] and 4 guests
