Wassel DC Conversion of PX
guygrrr
Main scooter: 1980 Vespa P187
ArmandTanzarian wrote:
guygrrr wrote:what year is yr P2? I've converted a couple and the trick has been getting the headlight sorted. On a '79 I ended up using a small relay to actuate the light when the key swith is on. Trailtech do a reg/rec with a built in relay that switches the circuit on when it sees voltage charging the battery, ie. when the bike is running. It's pretty trick.
What was the issue with the light?
Its not actually a P2, just a P2 engine in an old Vespa. As such there aren't any indicators etc. The engine must be fairly new since it was originally oil injection.
Do you modify the Stator in a similar way to a Lambretta one? i.e. just disconnect the earth and run it up to the Wassel Regulator. I'm in the middle of a complete rebuild and so I can do more or less what I like with the loom.
the head light runs a.c. off the stator. as this was a full d.c. conversion i had to figure something else out.
and as Byron sez, yes.
also, it may be wise to think about a master switch or a key switch of some sort to isolate the battery when not in use.
more can do, less doodoo.
