Page 2 of 3
Re: Hole Dimensions For Carb
Posted: Thu Apr 23, 2009 12:34 pm
by Bilko
That's a nice hole, do you mind if I use that idea?
Posted: Thu Apr 23, 2009 12:46 pm
by craze01
Nonot at all! its a tax disc holder cut up and used as a template! If you want close ups I will get you some tonight mate!!
Posted: Thu Apr 23, 2009 7:40 pm
by Bilko
Done. Used your idea of the tax disc for the template for the hole.
It was easier than I thought due to the carb rubbing against the panel and this gave me the point to use for marking and drilling.
When I get back home I'll post pics of how hard the carb was rubbing against the side panel.
Posted: Thu Apr 23, 2009 9:33 pm
by Bilko
Never checked closely the paint removed from inside the panel.
It was bad, the carb rubbed hard enough to put grooves in the metal. :oops:
But at least I knew where to cut the hole.
Just need to tidy the hole up a wee bit more.
I can't use the disc holder because of the curves in the side panel
Thanks for the help troops.
Posted: Fri Apr 24, 2009 7:42 am
by vegansydney
Sorry to hijack this thread but what is that seat in the GP posted above? I like! :D
Posted: Fri Apr 24, 2009 8:00 am
by Bilko
I'll find out for you.
Posted: Fri Apr 24, 2009 8:51 am
by TheSeeker
I love this scoot.
Just the right mix of well used/well maintained/not too bothered about winning any custom show prizes.
Going for the same philosophy with my rebuilt Li.
Great stuff.
Ben
Posted: Fri Apr 24, 2009 10:38 am
by Bilko
Thank you very much. It does look a lot worse in the flesh and although I was a bit embarrassed about the state of it. The positive posts in the show your scoot pics forum changed my mind.
Posted: Fri Apr 24, 2009 12:59 pm
by dapper
Bilko, can't you "persuade" the tax disc holder gently to the curve of your panel??
Posted: Fri Apr 24, 2009 3:19 pm
by Bilko
No mate, the curve too sharp.
I'd need to find something very flexible. :?
