Page 2 of 3
Re: Improving Lighting?
Posted: Mon Oct 01, 2012 8:58 am
by purple_pill67
ArmandTanzarian wrote:
purple_pill67 wrote: to fit a H4 conversion block.
Does anyone sell these ready made?
Not as far as I know. MB enquired iirc and min
1000 order/£30 cost price or summat as daft.
Its fairly easy to bodge yourself....i got the info on lcgb.
The speedo bulbs are same fitting as car interior lights so I got them on ebay for under 2 quida pair posted....they are dc so you need to do wassell too.
by purple_pill67
Posted: Mon Oct 01, 2012 11:46 am
by goldeneye
you can get a halogen bayonet fitting bulb, plugs straight in. use a l.e.d. speedo bulb and festoon bulb. i ride on unlit country roads to work, and it works well, on a SX headlight. Beedspeed do the bulbs for about 4 quid.
Posted: Mon Oct 01, 2012 12:52 pm
by wack 63
Don't get the one from Beedys without the filament shield though....
Posted: Mon Oct 01, 2012 1:40 pm
by faf
Wiil the H4 conversion work on an AC system?
Posted: Mon Oct 01, 2012 1:47 pm
by wack 63
Yes
Posted: Mon Oct 01, 2012 1:59 pm
by vRSG60
I bought the standarb bulb in a 40/45W format from my local motor factors for about £4. My previous bulb was a 20W and useless. I also converted to full DC
Posted: Mon Oct 01, 2012 3:38 pm
by dapper
Halfrauds do a straight fit 35w/35w halogen with shield for about £6 in their Bike It section Packet Number 417
Posted: Mon Oct 01, 2012 6:00 pm
by servetakid
goldeneye wrote:you can get a halogen bayonet fitting bulb, plugs straight in. use a l.e.d. speedo bulb and festoon bulb. i ride on unlit country roads to work, and it works well, on a SX headlight. Beedspeed do the bulbs for about 4 quid.
TBH, that sounds like what i need. I will have a look and make sure i get one with a shield...
Posted: Mon Oct 01, 2012 7:15 pm
by Rich_T
All the power and bulbs in the world won't make a difference if the loom and switch are a very cheap pattern part.
I rewired a new handle bar switch switch a couple of months back and found that although the power wire looked good and chunky, it actually only had 3 or 4 strands of very thin conductor in it. On a headlamp bulb this will make a very big difference.
