Page 2 of 2
Re: strange cyclical whirring sound
Posted: Thu Sep 27, 2012 9:54 am
by bristolmod
no definitely mwa mwa mwa mwa
ning ning blang dang is more rear hub IMO................
Posted: Thu Sep 27, 2012 3:27 pm
by Craig H
Pretty sure that was the noise I heard when on the way to Hastings my flywheel cowling broke up and hit the flywheel
Posted: Thu Sep 27, 2012 3:51 pm
by bristolmod
I've just had a, serious, thought...............
If I recall, this engine still has the "cushed" rear sprocket (the one with the internal springs around its circumference). I'm wondering if one of these has broken up?
I shall find out next week and report back.
Re: strange cyclical whirring sound NOW SORTED!
Posted: Mon Oct 01, 2012 12:32 pm
by bristolmod
Had a look this morning- expecting the worst, but initially couldn't find anything amiss. The chain was properly adjusted; no missing rollers or apparent wear; front sprocket secure; rear sprocket had no visible play.
However..........there were 2 radial marks on the kickstart teeth on 1st gear, and a corresponding wear "ridge" on the plunger housing on the K/S shaft. It was apparent the K/S mechanism was just touching first gear although there was no "click-click" sound as per normal.
A quick replacement of the plunger and a bit of "dressing" to its housing and replacement of the chaincase gasket and alls well.
FWIW I had to tighten up the front sprocket about 6 months back, and at that stage I replaced the chaincase gasket with a thin paper type one as it was all I had at that time- this time, I've used the "chunkier" version which is about twice the thickness= chaincase is now moved out away from the clutch area a fraction and the K/S mechanism now clears everything.
Thats my theory anyway!!
Thanks to all that offered ideas
Posted: Tue Oct 02, 2012 12:28 pm
by Special X
Sheeeit!!!! . . . . I've got that sound . . . and it's fitted with a thin gasket
Posted: Tue Oct 02, 2012 1:31 pm
by bristolmod
I can't believe the tolerances are that tight on a 50 year old bit of engineering, but it seems to have done the trick.
