Re: Vespa Enduro
Posted: Wed Sep 12, 2012 4:42 pm
A bit more on the work I did to the piston,
and checking the head clearance.
Slotted brakes and chrome hubs are a must for off-roading! Right?
Getting it together. I ended up with about 5mm under the cylinder and 2mm on top. The flywheel would bottom out on the case before it was fully tightened, so the case was relived of a few mm around the stator. Originally I planned on running a 3 speed tranny but I couldn't get the trans and shift box to play nice, so....
I have 20/20 carbs coming out the wazoo, but the addition of a velocity stack makes them a bit more fun.
