Re: 200cc alloy kit in a 150 casing
Posted: Thu Aug 23, 2012 2:21 pm
Don't use a 17 tooth with a scootrs pipe, it's very revvy and won't pull 4th gear with tall gearing. Stick to 5.3.
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
corrado wrote:Don't use a 17 tooth with a scootrs pipe, it's very revvy and won't pull 4th gear with tall gearing. Stick to 5.3.
you will need an 81 link got mine new iwis 81 link £39Gazbo72 wrote:Thanks Col. Might keep my eye out for a 17t front sprocket. Will I need a new chain or should I be ok with the old chain ???
Just had a check my gearbox is a li125 box with a 15/46 (5.65 ratio) set up. I suppose this will be very low gearing but OK around town driving but not so good on a run.col68 wrote:you will need an 81 link got mine new iwis 81 link £39Gazbo72 wrote:Thanks Col. Might keep my eye out for a 17t front sprocket. Will I need a new chain or should I be ok with the old chain ???
I must be lucky. But she did have a grumble when I got my gp , I had got a px166 & s2 ts1. But I have sold the vespa now so i have got some money in the pot :anbrgin; :anbrgin; :anbrgin;Gazbo72 wrote:Just had a check my gearbox is a li125 box with a 15/46 (5.65 ratio) set up. I suppose this will be very low gearing but OK around town driving but not so good on a run.col68 wrote:you will need an 81 link got mine new iwis 81 link £39Gazbo72 wrote:Thanks Col. Might keep my eye out for a 17t front sprocket. Will I need a new chain or should I be ok with the old chain ???
Think I will see what its like when in the scooter as is, Before I start buying more bits. Its getting hard enough to sneek things past the indoor boss with out ordering more stuff![]()
