200cc alloy kit in a 150 casing
Don't use a 17 tooth with a scootrs pipe, it's very revvy and won't pull 4th gear with tall gearing. Stick to 5.3.
Gazbo72
Main scooter: SX200
corrado wrote:Don't use a 17 tooth with a scootrs pipe, it's very revvy and won't pull 4th gear with tall gearing. Stick to 5.3.
Thanks for that corrado :)
col68
Main scooter: lambretta s2 li225 ts1
Gazbo72 wrote:Thanks Col. Might keep my eye out for a 17t front sprocket. Will I need a new chain or should I be ok with the old chain ???
you will need an 81 link got mine new iwis 81 link £39
Gazbo72
Main scooter: SX200
Just had a check my gearbox is a li125 box with a 15/46 (5.65 ratio) set up. I suppose this will be very low gearing but OK around town driving but not so good on a run.
Think I will see what its like when in the scooter as is, Before I start buying more bits. Its getting hard enough to sneek things past the indoor boss with out ordering more stuff :roll: :roll: :roll:
col68
I must be lucky. But she did have a grumble when I got my gp , I had got a px166 & s2 ts1. But I have sold the vespa now so i have got some money in the pot :anbrgin; :anbrgin; :anbrgin;
