Page 2 of 5
Re: Vespa GS 160 series 2 restoration
Posted: Thu Aug 23, 2012 11:57 am
by victor
lambretta not truck coil
missing ingnition switch on headset is how it should be
wrong toolbox lock - to me it seems correct, same as on my SS180 which should have the same glove box
flywheel is correct too, you are just missing three bolts.
Engine in place by
wheredowegonowbutnowhere, on Flickr
Posted: Fri Aug 24, 2012 8:10 pm
by gavi4t
just had a look at my old 160 gs mk2 and the floorboards are definatly upturned towards the front of the legsheilds ,your right vic but those floors are defo wrong as i thought sorry buddy ....
Posted: Sat Aug 25, 2012 11:58 am
by vegansydney
Everything you ever wanted to know and more on Vespa Sports models (GS/SS):
http://autos.groups.yahoo.com/group/vespa-sports/
I have a GS160 that needs a new floor and speaking from experience the replacement Vietnamese floorboards without the strengthening 'X's are an awful fit and need a lot of work to say the least.
Posted: Wed Sep 05, 2012 8:39 pm
by steve c
I have a load of pics from my mark 1 before I got it in bits and before and during new floor pan,and finished . I am Going top put them up for you but imageshack is not working
I would avoid acid stripping as you can't get rid of it unless you pay for the very high end washing and passivating version, with the floor off you easily blast the worst internal rust and treat it. The headset is right for an ac non battery gs use sportique switch( AKA usa or pakistan import) Can easily mod to fit the ignition,
. The floor looks right has a curve, gs150 and 160 are boat shaped sort off.
The fork links are expensive to buy so a better weld repair would be ideal.
steve
Posted: Sun Sep 16, 2012 7:27 am
by panamesc
seems to have all the correct details for a non battery mk2
glove box lock , no ignition key , correct light switch (painted in black) , even the horn looks good for me
Posted: Wed Sep 19, 2012 4:36 pm
by mn-001
Posted: Fri Sep 21, 2012 8:14 am
by panamesc
gs/ss wheels non offset
http://scootentole.sip-scootershop.com/ ... +_80170000
headset is ok
your gearchange too except for the neutral sign , but it's my mk1 , i can have a look on my mk2
Posted: Fri Sep 21, 2012 10:43 am
by Dryballs
mn-001 wrote:
1- I noticed it being VERY!!! side heavy to the engine side and of course I understand it is because the engine is there, but it seams excessive and i wonder if you would be able to ride it without tipping over. any ideas why?
2- is this the correct headset? It looks like it doesn't split in 2 like in most restoration pics I found.
3- is this the correct gear change handle?
4- are the wheels correct? I have read about different wheel sides, offset and non offset.
5- is the shape of the rear correct as there has been a lot of welding done there
6- which brand of wheels would it have had originally? because I doubt the made in Malaysia "The massive tyre company" branded wheels are original :-p
1 - yes its normal - they are fine to ride though
2 - Yes definately - where the hell were you looking for pictures of GS's? PX's have split headset and they are very different
3 - yes
4 - I think your front wheel rims are wrong. You should be able to get a set of wheel rims from Scooter centre or Sip that are correct. Make sure you get a spare wheel too for the left hand side. That might help your balance too
5 - I looks right... not ideal for the welding, but its roughly the right shape
6 - just get some new tyres for it. like some Michelins or something. Don't get hung up about original tyres
Posted: Fri Oct 19, 2012 4:49 pm
by mn-001
Posted: Fri Oct 19, 2012 5:53 pm
by Suede Ed
Bin it, get another one
