vespa px woes
Scooterso
joeswoonara wrote:hi lads ....thanks for the replies and i can see what your all saying ,but thats the thing that has got me so baffled ........the c.d.i is a new one so to is the stator plug lead, plug cap and even the carb although not new was taken off a mates running scooter ,all the parts you have mentioned have been changed for new after it started conking out
ducati CDI or mitsubishi?
pull the choke a little and drive, does it still die or keep running?
if you leave it sitting idle, will it idle for hours or die after just a short time? i.e. does it take full throttle to cause dying, or will sitting at idle still make it die?
fuel line should be 24" long, 30" long if new PX with little bracket on bottom of oil tank.
last scooter we had with a similar problem it was the longer fuel line, not in its little bracket being pinched by the oil tank.
