Page 2 of 5
Re: 2 stroke oil (again
Posted: Sat Aug 18, 2012 12:52 pm
by GP Kevo
Lubrication aside, I'd like to know what the flash point of the 2T I'm buying is, and that's something they don't put on the label.
Posted: Sat Aug 18, 2012 1:14 pm
by lozmondo
searching the www will normallyfind spec sheets which offer flash point figures
Posted: Sat Aug 18, 2012 1:37 pm
by warts
You worried about it going off in your toolbox?
Posted: Sat Aug 18, 2012 4:12 pm
by GP Kevo
Flash point is the temperature at which the oil will carbonise, losing it's ability to lubricate. I figure that since air cooled Lambretta engines, especially tuned ones, run hot, and since the fuels are getting so bad with ethanol additives that also cause engines to run hotter than otherwise, it can't hurt to use higher flash point 2Ts. If CHT is say, 240º C and your oil's flash point is 230º C, it'll convert to carbon there and on any other surface where the temp exceeds 230º C. But if the flash point is higher than temps in the engine, it won't carbonise and it'll continue to lubricate. Kind of the difference between using butter or vegetable oil in a frying pan. If you use really high temps for frying, butter will burn but oil won't. I'd think that a high flashpoint oil would be especially helpful in an overheating situation and might save your engine.
I just did an internet search for my oil's flash point and it's 274º C. Cheers, lozmondo!
Density at 20°C (68°F) ASTM D1298 0,927
Viscosity at 40°C (104°F) ASTM D445 157,4 mm2/s
Viscosity at 100°C (212°F) ASTM D445 19,2 mm2/s
Viscosity index ASTM D2270 140
Flash point ASTM D92 274°C / 525°F
Posted: Sat Aug 18, 2012 4:28 pm
by Muppet
cht and cylinder wall temps are the same? You run your engine on neat oil or you dilute it at 2-4% with petrol? Petrol has a flash point of? I love google specially for all there is to know about everything,
muppet,
Re: Re: 2 stroke oil (again
Posted: Sat Aug 18, 2012 4:53 pm
by drunkmunkey6969
Muppet wrote:cht and cylinder wall temps are the same? You run your engine on neat oil or you dilute it at 2-4% with petrol? Petrol has a flash point of? I love google specially for all there is to know about everything,
muppet,
Petrol is a fuel, and also a coolant. Oil is a lubricant. 230 degree flash point oil, in a 240 degree motor is no good, as you then have no lubricant.......and a dead engine.
Posted: Sat Aug 18, 2012 5:07 pm
by Muppet
drunkmunkey6969 wrote:Muppet wrote:cht and cylinder wall temps are the same? You run your engine on neat oil or you dilute it at 2-4% with petrol? Petrol has a flash point of? I love google specially for all there is to know about everything,
muppet,
i know im a muppet, what's your excuse
muppet,
Posted: Sat Aug 18, 2012 6:02 pm
by Muppet
It probably has to have a known flash point for it's safe handling distribution and storage under the hazardous chemical laws for fuels oils and chemicals etc; if someone googles it there's probably an answer that's relevant to the information contained on the rock oil packaging,
muppet,
Posted: Sat Aug 18, 2012 6:06 pm
by warts
Flash point is the temperature at which a fluid or rather its evaporation products will combust when a flame is passed across its surface. Not the temperature at which it carbonises, which will be much higher.
Engines - both 2t and 4t - are lubricated from below - no oil would survive the temperatures reached during combustion. So CHT or EGT are of themselves irrelevant to the discussion.
Only insofar as there must be a correlation between the working side of the piston which is obviously part of the combustion chamber, and the non working underside, which will only receive heat via conduction.
I am aware a 2t engine works both sides, but you know what I mean.
My experience was 25-30 yrs ago, so no data loggers or computer control of anything, we knew things had gone to far by looking at the underside of the piston. Tan was ok, brown was a frown and black was back to the drawing board.
I didn't ever have reason to measure the crankcase/block temperature itself, so have no idea what that would be, perhaps someone with access to a dyno could run an infra-red thermometer over a hard working crankcase?
Which would perhaps put peoples mind at rest about this question of flash point.
Posted: Sat Aug 18, 2012 6:11 pm
by warts
muppet,
Flash point is one of the basic quality markers of the base stock, along with viscosity and the test where they rub their balls together and which I have completely forgotten the name of. So it would be a way telling folk they are using decent materials, independent of the additive package.
