Re: SS180 tuning options?
Posted: Fri Aug 17, 2012 1:40 am
Fux wrote:My ss engine has a gs160 crankshaft, converted with ss180 rod so 12v conversion was possible. Runs really nice btw.
I got an extra SS180 barrel with the scoot and I am trying to work out what my options for more power are.
It looks to me that I could proberbly rebore my spare barrel and use a more modern piston. I`m not too smart when it comes to the nitty gritty of port timings and not quite sure how far I can take the barrel, or what the bore to piston clearence should be.
To me it seems that I could actualy use a px200 piston (Iv`e also been looking at Wisco pistons), and I think I read something about someone doing just that on MB`s old website.
Does someone remember, or know someone who has done it, who can pass on some info to me?
I havn`t done any work on vespa`s for years and i`m maybe a complete idiot as to the differences between a barrel and a modern piston not made for piston induction.
I`m thinking that I could modify and fit a Sip Road to make a good tourer. If it goes tits up, I can revert to what I already have.
Hi there Fux
I am working on a SS180 cylinder that has been bored to 66.5mm giving 208.4cc & has had some basic tuning work done to the piston crown to advance the transfer & exhaust timings, as the standard piston set up masks the ports at BDC by approx 3.0mm.
The PX200 piston that was used had the rear port welded up, but had a lot of distortion plus when cleaning up the welded area of the piston the previous owner had not done a good job of it! At present with the old piston the bore clearance is 0.010" & should be nearer 0.003"!
The modified piston crown is similar to the way the stage 2 lami pistons were modified in the 1960's with the area that matches the transfers & exhauxt ports had been filed down by 2.5mm. Not the best way to advance the port timings as the squish is not at a constant depth.
I am at present reworking the bored SS180 cylinder with a new welded up PX200 piston. Which I have now modified to improve the fuel flow through the piston & Cylinder ports. Also the head has been reprofiled to suit the new piston unit @ 67.0mm.
When finished I will have a costing for doing this conversion for those interested.
