Page 2 of 2
Re: Who converts 150 casings to 200 ??
Posted: Sun Jul 15, 2012 3:06 pm
by tavspeed
advantage of getting the cases done is you can use any of the 225 kits,maybe even rapido/rb250 if you wanted to push it.
could be a cost effective solution to buying a new indian 200 case at £300 ish.
does the primary compression increase if you convert the 150 case to 200.
Posted: Sun Jul 15, 2012 4:13 pm
by coaster
tavspeed wrote:advantage of getting the cases done is you can use any of the 225 kits,maybe even rapido/rb250 if you wanted to push it.
Can't see why it would, the cranks are all the same to the crank case are must all be the same I would have thought.
