Re: Ts1 exhaust stud wire kit!
Posted: Tue Apr 14, 2009 10:54 pm
Taff sells the allen bolts and lock wire kit. I understand that Ian had difficulty sourcing M7 allen bolts, which were then cross-drilled and hardened. That's why they were expensive.
However, I agree with Sean, especially as this is an ali barrel and the repetition of inserting and extracting the bolts will wear the threads in the barrel. I found them rather hard to use and required a stock of lock-wire as it couldn't be re-used.
On the LCGB site someone posted a thread about using some tab-washers to secure the nuts onto studs. I don't think these were commercially available.
