Page 2 of 2
Re: Jockeys rear brake, need some help please?
Posted: Thu Jul 05, 2012 3:53 am
by Robi D
I have another cam I can take down a mm or two. And I use the belt sandpaper when sanding the shoes so it should be even.
Thanks
Posted: Thu Jul 05, 2012 6:43 pm
by Supereibar
When fitting ours for the race, I filed both sides of the shoes down a little. The hub will tell you exactly what place is rubbing as you will see a lightly scuffed area on the shoe once you take the hub off. Get the file on the vise, and file it down very carefully. You are ready for the game then.
J.
PS: Jockey's are top blokes. We were very pleased with the results!!
Posted: Fri Aug 31, 2012 12:56 am
by netweasel
Also, when fitting that hub, make sure the tight fit is not actually the tire being squeezed against the engine prop stand you are using to elevate the rear of the bike!
I just installed the Jockeys rear brake. It works great. My only concern is the thin kidney-shaped plate where the new pivot post screws into. I think this portion of the adapter plate needs to be strengthened. It is very thin, and there are not many threads for an area that accepts so much force. There is room underneath for more metal or perhaps a nut to be welded to the plate.
On the kit I installed the threads seemed pretty weak to begin with.
Despite these concerns, I can now lock my rear wheel
Posted: Fri Aug 31, 2012 1:06 am
by Yanker
Does this help with kick-starting and the inevitable 'jumping out of the hands' problem that ensues? Thanks
Posted: Fri Aug 31, 2012 6:43 am
by 10 inch Terror
I fitted one a while ago and have just had my Scoot MOT'd. The guy who did the test said it was 'the best Lambretta brake he'd ever tested'. I'm very happy with it, well worth a little bit of fettling IMHO.
Posted: Fri Aug 31, 2012 9:51 am
by warts
Some of the shops in the ol' knacker bike world have a machine for trueing up brake shoes and adjusting to the size of the drum. No high spots, no out of round.
