10 min change of studs for SIP rims
molibdimum wrote:Anybody know the size and pitch of the left hand thread on the SIP stud . Turns out mine on the rear hub are 1mm smaller so I need a tap
http://scooterotica.org/forum/viewtopic ... ad#p143655
molibdimum
Cheers Martin.
Taking the hub off today and if its a Ramp I think Ill just go with a new hub.
molibdimum wrote:Cheers Martin.
Unscrupulous peeps may have ground off the "RAMP" name from inside the hub. :o
It may not be a Ramp but they're the only ones I've come across so far that use smaller studs than normal.
molibdimum
It is a RAMP Martin.
