Thin ring/quality piston options for standard GP/200dl?
soosh
0.05-0.065mm recommended clearance.
I think there's only a grade on the 66.0 Mahle piston, matches to the barrel.
The oversizes are straight, bore to clearance.
Special X
Why not use the Mahle 2 ring piston. Replace the rings with wire TS1 items and you've got a decent set up.
http://www.scooterrestorations.com/lamb ... ome-rings/
mickdale
Special X wrote:Why not use the Mahle 2 ring piston. Replace the rings with wire TS1 items and you've got a decent set up.
hello special x
are the ts1 items the ts1 200cc asso rings as i thought they were 1mm?
are they still available?
cheers
mick
Special X
You can buy a 1.5mm wire ring set at most tuners, I got my last set from Chiselspeed. 1mm rings on the Asso pistons came in to get round some problems with RB22s as I remember. TS1 kits had 1.5mm rings.
    Users browsing this forum: Google [Bot] and 11 guests
