Re: BGM Lambretta crank 60 x 110mm
Posted: Mon Nov 12, 2012 8:12 am
As per the original post, use a vernier gauge and measure the drive side oil seal shoulder "!Best measure the shoulder where the seal sits, the BGM item measured 9.32/9.29/9.30mmLamaddict wrote:Is there anyway you can identify the bad batch apart from the oil seal shoulder issue?
That then lead me to check other cranks Inocennti, MEC, Mazzucchelli, Omega and Indian which varied between 8.29mm and 8.48mm
