Re: Clinder head gasket sealent
Posted: Sat Apr 11, 2009 7:12 pm
Stringy wrote:Stag Wellseal is good.
Me too well rcommended available on she bay
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
Which number loctite do you use,as there are so many variationsJ1MS wrote:Ive used locktite for the last twenty plus years, before that I used to use gaskets that had a habbit of going pop if the Scooter was ridden too hard....Started using it after I ran a Yamaha DT175 piston with high comp head, the Locktite was reccommended by Dave Webster.....who was I to argue....
it is retainer, i have been using the same method. i think im prefering plain cylicone from bandq now though as ive now seen how solid it was on a head i recently took of. nothing was ever getting through that.celt wrote:Which number loctite do you use,as there are so many variationsJ1MS wrote:Ive used locktite for the last twenty plus years, before that I used to use gaskets that had a habbit of going pop if the Scooter was ridden too hard....Started using it after I ran a Yamaha DT175 piston with high comp head, the Locktite was reccommended by Dave Webster.....who was I to argue....
I note in sticky's book that MB uses loctite but the pictured tube which is being used is a bearing retainer??????
