TS1 gearbox help
woody
I've finally got round to finishing this and have gone for li 150 box and 17 , 46 . What sort of outcome should i expect from this type of set up ?
TS1-200
A 17 tooth front sprocket
A 46 tooth clutch bell
An LI150 Series 1, 2, 3 (Italian) standard gearbox
A 3.50 x 10 rear tire size
Ratio 4.6:1
RPM -1st- 2nd - 3rd - 4th - gears
1000 - 04 - 06 - 08 - 11 - MPH
2000 - 08 - 12 - 17 - 22
3000 - 12 - 19 - 26 - 33
4000 - 16 - 25 - 34 - 44
5000 - 20 - 32 - 43 - 55
6000 - 24 - 38 - 52 - 66
7000 - 29 - 45 - 60 - 77
8000 - 33 - 51 - 69 - 88
All taken from the scooterhelp page http://www.scooterhelp.com/tuning/lam.gear.calc.html
Keep on keepin on
soosh
What's it like on the road?
woody
soosh wrote:What's it like on the road?
only been up an down the road but seems like its got a bit of power , i,ve had the barrel re nicasiled and put new rings and reeds in so can,t thrash it yet so won,t know about top end for a while
woody
TS1-200 wrote:A 17 tooth front sprocket
Ratio 4.6:1
cheers mate
soosh
Sure,bit does it pull in top gear?
nelson pk
4.60 final drive on a non tuned TS1..........me thinks lots of changing down to 3rd against winds and slight gradients.
It's not untuned. Ralph has touched it. It'll pull 4.6 fine with a Micron pipe on it.
Unless Woody is the size of a walrus. In which case, I hear 5.2 is the gearing of choice these days.
nelson pk
Depends weather its been tuned for torque of exhaust port raised etc. Who knows!
In my opinion, for driveability 4.8 - 5.0 final drive on TS1's or monzas is best for tractability but it does depend on tune. 4.6 is high though in my opinion, even on a tuned TS1.
Depends what you want to do...........................
Do you want to cruise along at a steady speed, pulling up hills with relative ease without constantly changing down to get back on the power or are you happy cruising on the flat and then when you see a hill start accelarating big time in 4th to get the momentum to pull you up most of the way and then when it falls out of the power at almost the peak of the hill, change down, thrash the arse out of it in third and change back in to fourth again when you go down the other side........ but the big bonus of the over geared scoot is to tell your mates down the pub that with the wind behind you down hill (although you forget to mention that) that you had 90 mph out of it GPS. :lol:
And i am considerably less than walrus size thank you.........maybe a bit on the cuddly bear size but i'm quite happy. :D
woody
6FT an 11.5 stone guys if that makes any difference , not had it in top gear soosh as needs running in but gonna run it in with the 17 then if i don,t think it,ll suit me i,ll drop to 16 if it needs changing down a lot
    Users browsing this forum: Google [Bot], Google Adsense [Bot] and 11 guests
