Page 2 of 2
Re: TS1 porting images...
Posted: Fri May 11, 2012 12:53 pm
by camel
will be interesting to see the dyno graph....ive tuned my barrel exactly the same with the casing port and using v force reeds/dev tour pipe with a 35mikuni...i havnt done the transfers or the secondary boost...i get 23hp with 18lb of torque....not up there on the hp hit parade but it rides lovlely so im not too concerned
Posted: Fri May 11, 2012 4:27 pm
by Chris CSPE
drunkmunkey6969 wrote:
Chris CSPE wrote:How are the ring peg positions with the extra inlet work.
As you'll be aware, the bottom ring of the MB piston presents issues on that side with its peg position, but i came up with a suitable solution.
How are you routing the additional boost ports on your 7 port motors?
The seven port motors are tuned by Darrell, so unfortunately I can't comment on how Darrell has done it.
Wot are the reasons for the Extra port in the crank case/inlet, wot piston would you run with that modification, one with windows or no windows but a cut out instead.
Posted: Sun May 13, 2012 6:05 pm
by Chris CSPE
Wot piston configuration have you found works best?
Posted: Sun May 13, 2012 6:20 pm
by red
jason frost wrote:Always nice too see pictures of tuning work :D think I need to get out more
Yeah,yeah,yeah.
I'm sure I've heard that before :biggrin: :biggrin:
