Page 2 of 2
Re: Noise from the barrel area/ new build
Posted: Tue May 08, 2012 5:38 am
by eibarlad
73 Spanish 200
Posted: Tue May 08, 2012 10:00 pm
by ratty
Hi, have just had exactly the same thing happen on my new build, 20 mins with the wet and dry on a flat surface with the piston sorted it..
Posted: Tue May 08, 2012 11:34 pm
by cezeta
ive had the same too, i use 110 rods now so illuminates it
Posted: Thu May 10, 2012 5:49 pm
by eibarlad
Took 0.5mm off the skirt & the piston is clear.
Barrel/piston is now proved to be not the problem. Gear box/clutch has been checked for peace of mind really because the noise is certainly the top end. Just built it up & started it........same noise.
The only thing it can be is the crank or mag bearing but these are new. The noise has been audible since the first start up so the most likely answer now seems to be the big end was damaged right away with the piston skirt kissing the casing.
Any thoughts anybody ?
Posted: Fri May 11, 2012 10:25 pm
by Solerunner1
And there's no other marks or scratches on anything inside?
I have the same symptom(of course, not necessarily the same problem) on a 165 i just made. Fitted to the bike 2 days ago. My squish is a bit tight, but within range. I plan on just screaming the hell out it til it blows up. I'll let you know what it was when it fails ;)
Just a thought.....you said the piston is 67mm? Did you open up the head gasket from 66mm? Maybe the piston is tapping the ridge of the gasket?
Posted: Fri May 11, 2012 10:49 pm
by joespeed
8 thou clearance thats big big! why this large clearance?
one mans rattle can be another mans knock ,i see you are from carlisle is there no one (expert) you can take it to for a 'listen' and get a second opinion?
Posted: Sat May 12, 2012 1:08 am
by nelson pk
8 thou? are you sure...thats going to rattle big time. If you are sure of the piston to bore clearance measurement, thats your rattle right there.
Most piston slap can be heard at tickover.....if it disappears with higher revs its generally ok....if it doesn't , fix it.
Posted: Sat May 12, 2012 7:46 am
by eibarlad
Right from the off I changed the barrel & piston to take it out the equation.
Going to double check squish,timing & the fuel.
Next step is crank out & another one tried.
Posted: Sat May 12, 2012 7:56 am
by Special X
I think when you take the crank out you may find some shiney bits where the big end has been catching the crankcase. I had to take a fair bit off the crankcase to get enough clearance on my MECEUR 60mm crank.
