Page 2 of 3
Re: malossi 210 wont go over 55
Posted: Sat Apr 07, 2012 4:16 pm
by Danger
thanks very much for that ian , all help is greatly recieved ,
Posted: Sat Apr 07, 2012 6:11 pm
by Danger
told been to by the fella i rebuilt this engine for that its meant to already have a t5 4th fitted
Posted: Sat Apr 07, 2012 6:39 pm
by Bofs
If it ran well with the PM then I`d try that on it again for comparison.
Both the PM and the SIP make peak power between 6500 and 7500 so shouldn`t be that different.
The fact it won`t rev out even in 3rd never mind 4th seems odd.
Posted: Sat Apr 07, 2012 6:57 pm
by Danger
the pm is gone , its your old engine ivan bought off you years ago bofs , i really dont understand why it wont rev out in 3rd either
Posted: Sat Apr 07, 2012 7:44 pm
by sean brady scooters
is your throttle working ok ,is it fully opening the carb slide when wound back fully
Posted: Sat Apr 07, 2012 7:58 pm
by Danger
yeah sean pretty sure it is on idle to full open it will rev out quite cleanly
Posted: Sat Apr 07, 2012 8:43 pm
by bazman
Try a different stator could be electrical and lt coil breaking down under load, relatively easy and quick to change over. Also does it tickover and idle ok?
Posted: Sat Apr 07, 2012 9:53 pm
by Danger
bazman yeah scooter ticksover an idles ok plus scooter starts bang on one or two kicks
Posted: Sat Apr 07, 2012 10:27 pm
by bazman
Ok not oil seals then , when it revs out in 3rd does it tend to feel sluggish/not revving out or missing?
Posted: Sat Apr 07, 2012 10:47 pm
by Danger
its not missing , it flies through 1st an 2nd with ease once you put it into 3rd its feels tight with the more throttle you give it the tighter it gets , its like slamming your foot on the back brake an trying to open the throttle wont go anywhere
