New casing problem
mick1
Main scooter: Li Avanti 225
I took the hub off, turned it round and put it on back-to-front, and the layshaft spun freely...no grinding. Intresting that a 2mm spacer is available (why??).
the shim is to put under the cone to allow fitment of fatter tyres i believe
mick1
Used a bit of emery cloth around the rear brake casing, sorted it !! can't believe how little i had to take off, compared to the noise it was making...
Supereibar
:D its such a fantastic feeling when you get to the bottom of it innit?
