led indicators
very neat ,im liking that
rbgaz
good stuff lamblast, i like it a lot, mark come do mine for me please lol , not very good with electrics, i think all bikes should hav indicators by law btw
Bring it up to Norwich mate and it will be sorted
twenty eight
Agree very neat i think i may have go at fitting some
Just a thought. Couldn't you use a Serveta switch housing for your rocker switch?
lamblast
instead of the gp dip dazzle switch you can use the li switch with the ignition switch and use that as the rocker switch
That would look very tidy.
lamblast wrote:instead of the gp dip dazzle switch you can use the li switch with the ignition switch and use that as the rocker switch
that's what i have done on my Spanish 150, just needs a little bit of rewiring on the switch. or just get an Indian GP switch, but I'd then swap the cables for some decent ones anyway...
sparklymarkly
Nice job that Lamblast. I agree- in these days indicators are pretty much essential but they need to be subtle too!
I'm doing something similar on my GP rebuild using LEDs but probably using either a modded Seveta switch or an Indian one with it's guts transferred into a Serveta alloy body.
Quick question re your flasher unit wiring - is it battery to one flasher unit terminal then out from that to indicator switch live infeed?
lamblast
yes it is mate . my terminal for imput is marked "b" the markings for imput depend which country the flasher unit is made .if you struggle message me i can look it up for you .
