Page 2 of 2
Re: new pinasco kit
Posted: Fri Mar 09, 2012 8:26 pm
by ducksta
came with the pinasco kit m8 like ive said before built in pump no jets 27mm on top of reed valve piston ported not rotary inducted, pinasco are bringing another one out later this year that bolts streight on to the crank cases for rotary inducted motors.
Re: new pinasco kit
Posted: Mon Mar 12, 2012 11:22 pm
by a.lo
I,ve always wondered with these kits that the cooling air is seriously impeded by the reedblock,or has anyone proved otherwise?
Re: new pinasco kit
Posted: Thu Mar 29, 2012 9:58 pm
by ducksta
scoot started 2nd kick impressed myself sounds the biz, very very responsive trial ride at weekend then dyno time
Re: new pinasco kit
Posted: Fri Mar 30, 2012 11:06 am
by alcoholic maniacs sc
Re: new pinasco kit
Posted: Sat Mar 31, 2012 7:57 am
by ducksta
all you need is a sound bottom end, standard crank ect i have put a 21 tooth banded clutch in for saftey but its just plug and play went to it last night started 2nd kick with no choke hopefully get number plate this morning then round the streets i go lol
Re: new pinasco kit
Posted: Mon Apr 02, 2012 5:52 pm
by mick1
What % mixture are you running ?........check your clutch cable before you go out as well LOL schoolboy errors !!
Re: new pinasco kit
Posted: Mon Apr 02, 2012 7:24 pm
by ducksta
3% fully synthetic standard petrol, maiden run tonight very responsive felt smooth carb picks up instantly no blips,
http://s1248.photobucket.com/albums/hh4 ... =013-2.jpg clutch spot on mick good job you running in the avanti as the ts1 kicked your but sunday
Re: new pinasco kit
Posted: Mon Apr 02, 2012 7:42 pm
by mick1
ducksta wrote:3% fully synthetic standard petrol, maiden run tonight very responsive felt smooth carb picks up instantly no blips,
Bloody good eyesight Ducksta.....you must have been a mile behind at least !!
Re: new pinasco kit
Posted: Mon Apr 02, 2012 7:49 pm
by ducksta
sat behind geoff 50mtrs max m8 with slipping clutch plates not cable! rebuilt clutch last night sorted must admit was a bit fast ride back nearly knocked it into 4th but kept up ok,
Re: new pinasco kit
Posted: Wed Apr 11, 2012 5:16 pm
by ducksta
scoot on dyno this weekend so watch this space
