new pinasco kit
came with the pinasco kit m8 like ive said before built in pump no jets 27mm on top of reed valve piston ported not rotary inducted, pinasco are bringing another one out later this year that bolts streight on to the crank cases for rotary inducted motors.
I,ve always wondered with these kits that the cooling air is seriously impeded by the reedblock,or has anyone proved otherwise?
scoot started 2nd kick impressed myself sounds the biz, very very responsive trial ride at weekend then dyno time
- alcoholic maniacs sc
- registered user
- Main scooter: 6 volt mobility spaz chariot
- Contact:
looked at this kit in Armandos scooters and i think its the first time ive lusted over any vespa bits since the T5 was announced. its the coolest idea and quality looks amazing. my p200 is running like a punch drunk old sheepdog with bad knees at the moment so i might be in the market for a rally going makeover. is it just top end or do you need a crank and what price the entire rebuild. if you can pick up a mark1 p2 for around 1000 quid if you haggle hard with a desperate man it kinda puts into perspective these engine treats when they start reaching that money, i mean why not have a garage full of average scoots instead of a really good one!!??
all you need is a sound bottom end, standard crank ect i have put a 21 tooth banded clutch in for saftey but its just plug and play went to it last night started 2nd kick with no choke hopefully get number plate this morning then round the streets i go lol
3% fully synthetic standard petrol, maiden run tonight very responsive felt smooth carb picks up instantly no blips, http://s1248.photobucket.com/albums/hh4 ... =013-2.jpg clutch spot on mick good job you running in the avanti as the ts1 kicked your but sunday
mick1
- registered user
- Main scooter: Li Avanti 225
- Contact:
Bloody good eyesight Ducksta.....you must have been a mile behind at least !!ducksta wrote:3% fully synthetic standard petrol, maiden run tonight very responsive felt smooth carb picks up instantly no blips, http://s1248.photobucket.com/albums/hh4 ... =013-2.jpg clutch spot on mick good job you running in the avanti as the ts1 kicked your but sunday
sat behind geoff 50mtrs max m8 with slipping clutch plates not cable! rebuilt clutch last night sorted must admit was a bit fast ride back nearly knocked it into 4th but kept up ok,
scoot on dyno this weekend so watch this space
