Page 2 of 2
Re: Ideas/ thoughts please...........
Posted: Mon Feb 13, 2012 8:53 pm
by WINTERMODEL150
Monty wrote:my bets on the chain wrapped round the guide or guide off and round the sprocket :frog:
Had this before and got spat off,top chain guide spot welds had broken and rest of the guide got jammed in the crownwheel :cry: I weld them up these days just incase :D
Dean
Posted: Sat Feb 18, 2012 12:40 pm
by bristolmod
Update......................................
full of gloom and doom I'd decided it was either:-
1) Gudgeon pin circlip lost causing piston to jam
2) chain guides broken up into chain/ casing/ cogworks etc
Took off the chaincase cover and found that the "cush" mechanism on the crank was loose due to the retaining bolt not being tightened properly by someone. The collar and spring had moved outwards causing the collar to make contact with the casing. A quick check of all other parts confirmed no other damage/ problems elsewhere, and a refit of "UOS" (used old stock!!) parts cured the fault.
Scooter now running perfectly....................................till the next time
thanks to all for their thoughts, suggestions and offers to take the bike off my hands cheap :D
Posted: Sun Feb 19, 2012 1:36 am
by rosscla
That must have been one of those TFFT moments...
Posted: Sun Feb 19, 2012 9:31 am
by bristolmod
yep- definitely a TFFT moment!
The loss of a bit of power must have been when the collar was grinding away at the chaincase- this was at speed. As I slowed, the collar and case "welded" themselves to each other- hence the lock up.
Job totally sorted in under an hour- normally one problem leads to another, then another, then another. This one was just "text book" :D
No doubt I'll pay in the future :roll:
