Page 2 of 3
Re: chiselspeed ADS 3
Posted: Wed Feb 08, 2012 7:51 pm
by Bilko
I need a pipe. Might go for one of these when I get enough money together
Posted: Wed Feb 08, 2012 8:34 pm
by corrado
RobD wrote: Had a few issues fitting it though as the pipe wouldn't fit properly into the stub manifold for the cast barrel. Fortunately I noticed before I tried to fit it to the scooter. It slid easily into the TS1 sub but where the tube is ovalled to fit the flange for the cast stub it had distorted it all and the pipe wouldn't go in more than a few millimetres. A few hours of dremelling the stub, squeezing it in the vice and eventually cutting about 8mm off the end of the pipe itself meant it went on but I still had the slot the holes in the crankcase mount by about 8mm to get it to fit unstressed.
You couldn't not notice it on mine as you couldn't get the stub off the downpipe without a hammer, so had to go through the above process. I should have fired it back really. Sounds like the problem hasn't been addressed. It's not just on the ADS but all pipes made by NK.
Posted: Wed Feb 08, 2012 8:38 pm
by Bilko
I've changed my mind
Posted: Wed Feb 08, 2012 8:41 pm
by corrado
It's not a problem on the TS1 stub Bilko just the piston port ones.
Posted: Wed Feb 08, 2012 8:45 pm
by Darrell Taylor
i got one from martin at chiselspeed a few weeks ago and it fits up fine
if your concerned about fitment then you could ask for it to be checked before it gets posted out which im sure martin would be happy to do
Posted: Wed Feb 08, 2012 9:27 pm
by camel
corrado...what set up do you use...gearing and top end....whats your take
Posted: Wed Feb 08, 2012 10:58 pm
by micksnake
Got a ADS 3 on mine " Sign of the snake", no trouble with the fitting at all. On a TS 225 sounds great and performes brilliant, love it.
Posted: Wed Feb 08, 2012 11:03 pm
by Bilko
Thanks Martin, Thanks Mike.
Hopefully have one by July!
Posted: Thu Feb 09, 2012 1:42 am
by corrado
camel wrote: corrado...what set up do you use...gearing and top end....whats your take
Mine was on a Muggy 225 with TM24 carb. Can't remember the gearing, except that I was using an AF close ratio box, though I'd guess at 19 x 46. Holed the piston playing about trying to get the jetting right so the pipe never really had a fair trial. It's going back on when I rebuild it though.
Posted: Tue Apr 17, 2012 10:00 pm
by Devlam
Any thoughts what this might be like on an imola?
