Page 2 of 2
Re: PX Disc Brake Conversion.
Posted: Thu Feb 16, 2012 12:54 am
by Ivan_200
not so ordinary, but i did a piaggio skipper/skr complete front fork with disc conversion. all i need now is a thinner brake line to pass it through the frame.
Posted: Thu Feb 16, 2012 10:27 am
by gavi4t
if you take off the drum hub off your px as long as its a 20mm spindle ,remove the circlip that holds it onto the fork link inside the hub ,the disc hub will fit straight on then drill a hole in your mudguard for the hydrolic hose to pass through and get a disc headset bottom and your done ,i did this to a freinds t5 and has been fine for 5 years now hope this helps cheers gavi
