PX Disc Brake Conversion.
Ivan_200
Main scooter: Vespa PX125/177
not so ordinary, but i did a piaggio skipper/skr complete front fork with disc conversion. all i need now is a thinner brake line to pass it through the frame.
gavi4t
Main scooter: lambretta gp450
if you take off the drum hub off your px as long as its a 20mm spindle ,remove the circlip that holds it onto the fork link inside the hub ,the disc hub will fit straight on then drill a hole in your mudguard for the hydrolic hose to pass through and get a disc headset bottom and your done ,i did this to a freinds t5 and has been fine for 5 years now hope this helps cheers gavi
    Users browsing this forum: Google [Bot] and 11 guests
